Huawei
P40 lite 5G
Huawei P40 lite 5G
f-2a1cacb3-8bdc-4faf-ae12-ecefc097d38b
f-a674966d-ce0f-4a63-8cee-78138fbfe860
f-daea9c61-7a6b-4dfe-a7ae-2c9df301d429
f-26ebb6c4-75a0-4a28-b17b-8fdb06f173f5
f-3264d04f-477f-461d-b3cb-ad992c58e37d
f-15894f03-5d79-4c87-aa7f-f7d16d4eb8ab
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Press Mobile network.
Press SIM management.
Press the indicator next to the required SIM to turn use of the SIM on or off.
Press the field next to “Default mobile data” below the required SIM.
Press Default calling SIM.
Press the required setting.
