Huawei
P40 Lite
Huawei P40 Lite
f-d24a5445-dcf8-4614-99bb-2ee2e5c45294
f-5ea505de-7f5a-4627-a57b-d13601b2012f
f-9f5e3a01-7def-411c-9a8c-ba26221b4e61
f-16430172-0ba5-4942-b506-7561faf86e57
f-70476615-45d8-43d0-9098-1337f5ad24e3
f-0188950b-f8ce-47bf-9e44-8f93097f07e6
Can you make a voice call?
