Huawei P40 Pro
Installing apps from Huawei AppGallery
You can add new functions to your phone by installing apps from Huawei AppGallery. To install apps, you need to set up your phone for internet.
Press AppGallery.
Press the search field.
Key in the name or subject of the required app and press the search icon.
Press the required app.
Press INSTALL and follow the instructions on the screen to install the app.
