Huawei
P40 Pro
Huawei P40 Pro
f-68820e22-cce0-4e67-aef0-bb5aab9779da
f-06c071a9-fd11-4bf7-b744-39fc44a814c4
f-b91a16d7-edb4-4fce-bf25-c05d59517602
f-afd6e8b2-6543-480b-a0b7-316b6591b461
f-2ac96897-81fc-4309-a202-a6ea4ccfad30
f-01f5ba1c-9be7-4db8-8afe-0373d0e10ad8
Can you make a voice call?
