Microsoft
Surface Duo
Microsoft Surface Duo
f-d24da4d4-13d5-4f4b-bb7c-0fc54ef6f548
f-d8cc0311-13a5-43e3-aaf2-c85b670d94fb
f-2d2f002d-d232-48b5-9ecf-0c5ff742a0c6
f-da79d204-ea8d-4a8f-98c6-239aa1747f5e
f-17bc4c99-b40f-47b8-83af-39b32a8f7788
f-9f10e683-70fe-4a67-8128-8a140a782fa1
Using dual-screen
You can use both phone screens simultaneously, e.g. for multitasking or gaming.
Press the required app on one screen.
Step 1 of 19
Slide your finger slowly upwards from the bottom of the screen and drag the app to the other screen.
Step 2 of 19
Step 3 of 19
You can use two different apps on each screen at once.
Press the required app on the other screen.
Step 4 of 19
Press and hold the first app.
Step 5 of 19
The first app in the app group will open on the left screen. If you often use two apps together, you can create an app group in order to open both apps on each screen at once.
Press Groups.
Press Groups.
Step 6 of 19
Press Groups.
Press the second app.
Step 7 of 19
The second app in the app group will open on the right screen. If you often use two apps together, you can create an app group in order to open both apps on each screen at once.
Press Done.
Press Done.
Step 8 of 19
Press Done.
Press the text input field and key in the required name of the app group.
Step 9 of 19
Press Okay.
Press Okay.
Step 10 of 19
Press Okay.
Press the app group to open the two apps at the once.
Step 11 of 19
Press the required app.
Step 12 of 19
Some apps on your phone can be displayed in enhanced mode on both screens.
Slide your finger slowly upwards from the bottom of the screen and drag the app to the middle of the two screens to turn on enhanced screen mode.
Step 13 of 19
Slide your finger upwards starting from the bottom of the screen to end enhanced screen mode.
Step 14 of 19
Open the required app in enhanced mode.
Step 15 of 19
You can turn on laptop mode on your phone and use one screen as keyboard.
Place your phone in a horizontal position.
Step 16 of 19
Press the text input field to activate the keyboard on the bottom screen.
Step 17 of 19
Fold your phone so the two screens are facing outwards to turn on single screen mode.
Step 18 of 19
You can fold your phone and use one screen only. You can choose which screen should remain active.
To change between the screens, point the screen which is turned off towards you and press twice anywhere on the screen.
Step 19 of 19
