Microsoft Surface Duo
Solution 2 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press Network and Internet.
Press Hotspot and tethering.
Press Wi-Fi hotspot.
Press Hotspot name and key in the required name for the Wi-Fi hotspot.
Press OK.
Press Security.
Press WPA2-Personal to password protect your Wi-Fi hotspot.
Press Hotspot password and key in the required password.
Press OK.
