Microsoft
Surface Duo
Microsoft Surface Duo
f-d24da4d4-13d5-4f4b-bb7c-0fc54ef6f548
f-d8cc0311-13a5-43e3-aaf2-c85b670d94fb
f-2d2f002d-d232-48b5-9ecf-0c5ff742a0c6
f-da79d204-ea8d-4a8f-98c6-239aa1747f5e
f-17bc4c99-b40f-47b8-83af-39b32a8f7788
f-9f10e683-70fe-4a67-8128-8a140a782fa1
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
