iPad (10th Gen)
Using Do Not Disturb
If you don't want to be disturbed by messages or notifications, you can set your tablet to silent mode for a specified period of time. You can also select that you want to receive messages from certain contacts even though your tablet is in silent mode.
Step 1 of 9
Press Focus.
Step 2 of 9
Press Focus.
Press Do Not Disturb.
Step 3 of 9
Press People and follow the instructions on the screen to select which contacts you would like to receive calls and notifications from when Do Not Disturb is turned on.
Step 4 of 9
Press Apps and follow the instructions on the screen to select which apps you would like to receive notifications from when Do Not Disturb is turned on.
Step 5 of 9
Step 6 of 9
Press the indicator next to "Time-Sensitive Notifications" to turn display of timed notifications on or off when Do Not Disturb is turned on.
Press arrow left.
Step 7 of 9
Press arrow left.
Press Add Schedule and follow the instructions on the screen to select settings for automatic activation of Do Not Disturb.
Step 8 of 9
Step 9 of 9
