iPad Air 13”
Using notifications
You can set your tablet to display notifications about new messages and appointments in the status bar at the top of the screen.
Step 1 of 23
Press Notifications.
Step 2 of 23
Press Scheduled Summary.
Step 3 of 23
Step 4 of 23
Press the indicator next to "Scheduled Summary" to turn on the function and follow the instructions on the screen to set the notification summary.
You can set your tablet to give you a personalised notification summary at a time of your choosing.
Press arrow left.
Step 5 of 23
Press arrow left.
Press Show Previews.
Step 6 of 23
To select notification preview on the lock screen, press Always.
Step 7 of 23
To select notification preview only when your tablet is unlocked, press When Unlocked.
Step 8 of 23
To turn off notification preview, press Never.
Step 9 of 23
Press arrow left.
Step 10 of 23
Press arrow left.
Press Screen Sharing.
Step 11 of 23
Step 12 of 23
Press the indicator next to "Allow Notifications" to turn the function on or off.
You can turn display of notifications when using SharePlay or Screen Mirroring on or off.
Press arrow left.
Step 13 of 23
Press arrow left.
Press the required application.
Step 14 of 23
Step 15 of 23
Press the indicator next to "Allow Notifications" to turn notifications for the selected application on or off.
Step 16 of 23
Press the indicator next to "Time-Sensitive Notifications" to turn the function on or off.
If you turn on the function, notifications from the selected app will be displayed immediately and will be visible on the lock screen for one hour.
Press Notification Grouping.
Step 17 of 23
This function enables you to select whether notifications should be grouped or be displayed individually.
Press the required setting.
Step 18 of 23
Press arrow left.
Step 19 of 23
Press arrow left.
Step 20 of 23
Step 21 of 23
Press the required notification and follow the instructions on the screen to use the selected function.
Step 22 of 23
Step 23 of 23
