iPhone 14 Pro Max
Step 1 of 12
Press General.
Step 2 of 12
Press General.
Press Transfer or Reset iPhone.
Step 3 of 12
Press Reset.
Step 4 of 12
If you choose to restore settings only, all phone settings are restored but contacts, audio files, videos and appointments will not be deleted.
Press Reset.
Press Reset All Settings.
Step 5 of 12
Step 6 of 12
Press Reset All Settings. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use.
Step 7 of 12
Press Erase All Content and Settings.
Step 8 of 12
If you choose to restore settings and data, settings, contacts, audio files, videos and appointments are deleted. When you've restored settings and data, you need to activate your phone.
Press Continue.
Step 9 of 12
Press Continue.
Press the required setting.
Step 10 of 12
Press Turn Off.
Step 11 of 12
Press Turn Off.
Key in the password for your Apple ID and press Erase iPhone. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use.
Step 12 of 12
