iPhone 14 Pro Max
Turning on Visual Voicemail
Using Visual Voicemail, you can see a list of the messages you've received on your voicemail, play them back or delete them. You can also record a personal greeting or select a default greeting.
Apple iPhone 14 Pro Max
Step 1 of 1
Send a text message with the text IPHONE VISUAL to 150. You will receive a text message from us when your Visual Voicemail has been turned on.
