You can select various accessibility settings for screen, sound and interaction making it easier to use the phone functions.
Press Accessibility.
Press the required category below "VISION" and follow the instructions on the screen to select the required settings.
Press the required category below "PHYSICAL AND MOTOR" and follow the instructions on the screen to select the required settings.
Press the required category below "HEARING" and follow the instructions on the screen to select the required settings.
Press the required category below "SPEECH" and follow the instructions on the screen to select the required settings.
Press the required category below "GENERAL" and follow the instructions on the screen to select the required settings.
