Motorola
Edge 30 Neo
Motorola Edge 30 Neo
f-93e9a634-e984-49da-b3c0-4ecf46ea52a0
f-1d0a17fb-5c02-427f-a490-dc32516cbcbf
f-ea7de478-9867-4af5-ba1a-3cc132157dff
f-820c2a10-229b-4da3-9ce8-c76f97e4c992
f-76a750bd-fe54-4d4b-9975-c5269c46baf7
f-631bd3ce-6900-4cbd-9863-cad31b369587
If you can't send and receive picture messages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive picture messages.
Can you make a voice call?
