Motorola
Edge 30 Neo
Motorola Edge 30 Neo
f-93e9a634-e984-49da-b3c0-4ecf46ea52a0
f-1d0a17fb-5c02-427f-a490-dc32516cbcbf
f-ea7de478-9867-4af5-ba1a-3cc132157dff
f-820c2a10-229b-4da3-9ce8-c76f97e4c992
f-76a750bd-fe54-4d4b-9975-c5269c46baf7
f-631bd3ce-6900-4cbd-9863-cad31b369587
Activating your phone
You need to activate your phone before using it for the first time and after a factory reset. Before you can activate your phone, you need to insert your SIM into your phone.
Press On/Off.
Press On/Off.
Step 1 of 10
Press On/Off.
If your SIM is locked, key in your PIN and press arrow right. The default PIN is 1111.
1111
1111
Step 2 of 10
Press the drop down list.
Step 3 of 10
Press the required language.
Step 4 of 10
Press START.
Press START.
Step 5 of 10
Press START.
Step 6 of 10
Step 7 of 10
Press the indicators next to the required settings to select them.
Step 8 of 10
Press Accept & Continue.
Step 9 of 10
Press Don't copy and follow the instructions on the screen to finish the activation.
Step 10 of 10
You can also transfer content from another phone or restore the content of a Google One backup.
