Motorola
G53 5G
Motorola G53 5G
f-9cd5fe88-cb63-4cb7-91aa-404c94f33716
f-68fa002f-566d-4405-907b-73c03f232852
f-3b46ba9b-2d55-4da0-9b01-d16d95e16b23
f-2e6abf35-db21-4d4d-8550-28a63c1c90a6
f-e0802053-d044-4fed-9715-d0fa3882cda3
f-87c7ceeb-c590-4cfc-a6b9-e1494c073ede
f-5ade647c-94da-4161-ad02-958a1ef67f6c
f-64d62aaa-cc50-4ded-8903-35fc857ce4ae
Can you make a voice call?
