Motorola
Moto G50 5G
Motorola Moto G50 5G
f-d6182f59-9cdd-4dd6-b3c6-646291f0e0ac
f-ef42908d-856c-40fd-9be5-ff53a0d6aae9
f-fbcd9c55-27a4-4f1f-86c9-7d83a992409f
f-2d4ed9ca-c5e5-4c17-8a77-0c47d154578d
f-60f82fbe-426f-4d7e-a7ba-5b305dc5ec97
f-cb6d2f1e-4aa0-4141-bbe4-641ce55a42fc
Can you make a voice call?
