Motorola
razr 40
Motorola razr 40
f-6e09b8d8-52cc-49d8-91fc-8e0143b2a46b
f-c0319212-1710-4d18-a4b4-842b28e010ec
f-8d0f08c4-a17b-42c6-ad6d-9b91272f7867
f-25c02a4f-4bc0-4dfa-9d5a-64634b42e18b
f-4226be60-204f-4662-83e7-8c165c8bff39
f-408ed419-a4d6-44ab-aaf8-335ad955948a
f-391b8d3a-b7a6-4202-8966-50a8fa1e63d4
f-22302ff6-a730-4593-8503-baed6a61dd13
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Press Sound & vibration.
Press Phone ringtone (‹SIM slot›).
Press the required ring tones to hear them.
Once you've found a ring tone you like, press OK.
To use a different ring tone than the default ones, press Add ringtone and follow the instructions on the screen to select the required ring tone.
