Motorola razr 40 ultra
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Press Sound & vibration.
Press Phone ringtone (‹SIM› slot).
Press the required ring tones to hear them.
Once you've found a ring tone you like, press OK.
To use a different ring tone than the default ones, press Add ringtone and follow the instructions on the screen to select the required ring tone.
