OnePlus
7 Pro 5G
OnePlus 7 Pro 5G
f-14d789db-1d1b-4a29-b4d6-63f24e6ae290
f-50b8a90e-e293-408e-b97d-9c72460aca82
f-e35c9925-d6c4-453b-a7ff-67e071235f2f
f-28387184-cac7-42de-87d8-b8d102ebb6e8
f-98fdaffe-c3e3-4759-92ff-54434ceef355
f-393b7784-bd3c-4025-997b-9e1e561d8848
Can you make a voice call?
