OPPO A16s
Solution 2 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press Connection & sharing.
Press Personal hotspot.
Press Personal hotspot settings.
Press the field below "Name" and key in the required name.
Press Security.
Press WPA3 PSK to password protect your Wi-Fi hotspot.
Press the field below "Password" and key in the required password.
Press the save icon.
Press the indicator next to "Personal hotspot" to turn on the function.
