OPPO
A16s
OPPO A16s
f-a39941f6-bfa0-4a1d-8e3b-cefa55d1c464
f-25311e34-f1c7-451a-8441-11acf6ed37b8
f-615829a9-3d9e-4ff3-a6f6-b18d87377a11
f-4d78f26f-75b6-435a-882b-e358dabb457a
f-e123a593-b233-4c89-84df-166372b2d7ad
f-7e27ddcc-36c2-4400-89bd-4ca7f637b2c2
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
