OPPO
A17
OPPO A17
f-e7bcdaaf-2ed0-4100-a69c-eddace40450a
f-e35dfd5a-c31f-4dbf-9602-2a53f503b53a
f-c1756b36-27bb-494c-a0ee-cb7a9123d2a9
f-40d8e280-0b61-4afe-b960-3c0191d19e5d
f-42cc310b-8594-4bca-b7f0-ad5f19f1ff78
f-5e7ae343-dbdf-4179-b26c-85fa0d316966
Solution 1 of 3: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Press Wi-Fi.
Press Wi-Fi.
Press Wi-Fi.
Press Wi-Fi Assistant.
Press the indicator next to "Auto-connect to the best Wi-Fi" to turn on the function.
Press the indicator next to "Auto-switch to mobile network" to turn the function on or off.
