OPPO A17
Solution 3 of 3: GPS position usage for applications is turned on
Press Location.
Press Google Location Accuracy.
Press the Return key twice.
Press Apps.
Press App management.
Press the required app.
Press Permissions.
Press Location.
Press the required setting.
