OPPO A17
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Press Mobile network.
Press the required SIM.
Press the indicator next to "Enable" to turn use of the SIM on or off.
Press the Return key.
Press Calling.
Press the required setting.
Press Internet.
