OPPO
A54 5G
OPPO A54 5G
f-34473aff-ef5c-4354-b053-412deace75fb
f-4b13728d-f8ad-4295-bfa1-d5654c6f9b12
f-943f68f8-2a2c-4f04-91ba-efb973a6d76c
f-16491057-507f-4b60-9efa-511fa02c226c
f-02049573-f6b7-42f0-9ac5-cfc4940fb5f3
f-ec727b60-e013-4762-b429-89d67a5ef608
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Step 1 of 14
Step 2 of 14
Press SIM card & mobile data.
Step 3 of 14
Press the required SIM.
Step 4 of 14
Press the indicator below
Step 5 of 14
Press the indicator below "SIM Info & Settings" to turn use of the SIM on or off.
Press the Return key.
Step 6 of 14
Press Calling.
Press Calling.
Step 7 of 14
Press Calling.
Press the required setting.
Step 8 of 14
Step 9 of 14
Press Mobile data.
Press Mobile data.
Step 10 of 14
Press Mobile data.
Step 11 of 14
If you change SIM, press Switch.
Step 12 of 14
Step 13 of 14
Step 14 of 14
