OPPO
A54s
OPPO A54s
f-3d6c505e-30d8-4240-9d78-5a670694ff2b
f-ef4649dc-c04a-43d4-bfca-52e6482b97e3
f-25425e90-8baa-4579-83c7-7d438bfea916
f-09bd72ef-7686-48b0-a394-f5b85af007fa
f-573ca3ec-1fd2-4e14-acb3-c7869b580b16
f-9e1b32d5-3775-432d-a616-decbd4c76136
Can you make a voice call?
