OPPO
A60
OPPO A60
f-11e223e2-2f8f-4228-8a65-af04af342d68
f-e3c02c0a-df86-4646-a5b1-0c0c3664800d
f-d15371d9-498c-449e-a6b5-343d69e9918b
f-cea7f7ba-5fee-4429-81c5-3cbcc56e3857
f-c61c1335-5ddb-4f7e-a91b-f19e20f35365
f-f3994b2e-5b66-4043-9088-d89a289b023f
f-5ec91a6e-efaf-4541-b147-977d07b5ac5a
f-3ea3926a-b15b-4276-9ea4-e3be1437f4dc
Can you make a voice call?
