OPPO A60
Solution 3 of 4: GPS position usage for applications is turned on
Press Location.
Press the indicator next to "Location Services" to turn the function on or off.
Press Location Accuracy.
Press the Return key twice.
Press Apps.
Press App management.
Press the required app.
Press Permissions.
Press Location.
Press the required setting.
