OPPO
A78 5G
OPPO A78 5G
f-fdd04c18-7774-43d7-907e-a6d59bb4e1fb
f-5050a6fc-fb09-4582-9ca7-1f98380ae56b
f-4a1bc0e5-80c9-4240-8421-5dd2bb6a14d5
f-1ecd4185-2ae8-4d03-99da-1ab33939e2bf
f-7833af5c-52cb-4ff6-86f8-4c6f56665bcf
f-b7205d05-57d7-4def-9f22-0d69ff21390a
Can you make a voice call?
