OPPO
Find N2 Flip
OPPO Find N2 Flip
f-e5f4aed4-3970-4f30-9281-8cae2cd1b4e7
f-a18ceff3-03c2-4d79-a0bc-f16a4b6d5517
f-73648a17-925f-403e-a222-b1e3ab94a47b
f-e2ee1346-cd1b-43b6-bfa9-a74f0c5c43d0
f-3c5e44f7-9dd8-4829-8104-df2f8b8099b2
f-39e287d0-de15-4a70-97c1-4a9052b3c204
Solution 3 of 4: GPS position usage for applications is turned on
Step 1 of 15
Step 2 of 15
Press Location.
Press Location.
Step 3 of 15
Press Location.
Step 4 of 15
Press the indicator next to "Location" to turn the function on or off.
Press Google Location Accuracy.
Step 5 of 15
Step 6 of 15
Step 7 of 15
Press the Return key twice.
Step 8 of 15
Press Apps.
Press Apps.
Step 9 of 15
Press Apps.
Press App management.
Step 10 of 15
Press the required app.
Step 11 of 15
Press Permissions.
Press Permissions.
Step 12 of 15
Press Permissions.
Press Location.
Press Location.
Step 13 of 15
Press Location.
Press the required setting.
Step 14 of 15
Step 15 of 15
