OPPO
Find N2 Flip
OPPO Find N2 Flip
f-e5f4aed4-3970-4f30-9281-8cae2cd1b4e7
f-a18ceff3-03c2-4d79-a0bc-f16a4b6d5517
f-73648a17-925f-403e-a222-b1e3ab94a47b
f-e2ee1346-cd1b-43b6-bfa9-a74f0c5c43d0
f-3c5e44f7-9dd8-4829-8104-df2f8b8099b2
f-39e287d0-de15-4a70-97c1-4a9052b3c204
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Step 1 of 11
Step 2 of 11
Press Mobile network.
Step 3 of 11
Press the required SIM.
Step 4 of 11
Step 5 of 11
Press the indicator next to "Enable" to turn use of the SIM on or off.
Press the Return key.
Step 6 of 11
Press Calling.
Press Calling.
Step 7 of 11
Press Calling.
Press the required setting.
Step 8 of 11
Press Internet.
Press Internet.
Step 9 of 11
Press Internet.
Step 10 of 11
Step 11 of 11
