OPPO
Find X2 Lite
OPPO Find X2 Lite
f-fe128992-30c7-48b8-878d-c986906c0dd8
f-25fa94eb-a4b1-4bd2-a943-acb61ce78fab
f-0b320f57-0f93-47f4-8643-1a01a8bc3a37
f-0c98b1b8-8677-41dd-921a-138693caf79a
f-ed85f807-391f-4f24-8128-c2db79f7ea0c
f-b29b30a9-622e-4ba9-8234-aeca2f2f1755
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
