OPPO Find X2 Lite
Solution 2 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press Other Wireless Connections.
Press Personal Hotspot.
Press Personal Hotspot Settings.
Press Name and key in the required name for the Wi-Fi hotspot.
Press Security.
Press WPA2 PSK to password protect your Wi-Fi hotspot.
Press Password and key in the required password.
Press Save.
Press the indicator below "Personal Hotspot" to turn on the function.
