OPPO
Find X2 Lite
OPPO Find X2 Lite
f-fe128992-30c7-48b8-878d-c986906c0dd8
f-25fa94eb-a4b1-4bd2-a943-acb61ce78fab
f-0b320f57-0f93-47f4-8643-1a01a8bc3a37
f-0c98b1b8-8677-41dd-921a-138693caf79a
f-ed85f807-391f-4f24-8128-c2db79f7ea0c
f-b29b30a9-622e-4ba9-8234-aeca2f2f1755
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
