OPPO
Find X2 Neo
OPPO Find X2 Neo
f-f350c4aa-e93a-4f63-97de-9015571ad8cf
f-b795841c-4a76-4479-9b94-8979a6bdff8a
f-e59e546e-e482-48a9-8594-38ad24e046f9
f-9f24d2a4-cb22-4fa8-bcf7-cf738273cc4d
f-f1c18343-56d1-452e-a300-1cf0b55405ed
f-57ebd99e-bdf1-4fc6-ae6c-bd6c42d6d46f
Can you make a voice call?
