OPPO
Find X2 Neo
OPPO Find X2 Neo
f-f350c4aa-e93a-4f63-97de-9015571ad8cf
f-b795841c-4a76-4479-9b94-8979a6bdff8a
f-e59e546e-e482-48a9-8594-38ad24e046f9
f-9f24d2a4-cb22-4fa8-bcf7-cf738273cc4d
f-f1c18343-56d1-452e-a300-1cf0b55405ed
f-57ebd99e-bdf1-4fc6-ae6c-bd6c42d6d46f
Solution 2 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Press Wi-Fi.
Press Wi-Fi.
Press Wi-Fi.
Press Wi-Fi Assistant.
Press the indicator next to "Automatically Select the Best Wi-Fi".
Press the indicator next to "Auto-Switch to Mobile Network" to turn the function on or off.
