OPPO Find X2 Neo
Solution 1 of 4: GPS position usage for applications is turned on
Press Location.
Press Google Location Accuracy.
Press the Return key twice.
Press App Management.
Press App Permissions.
Press Apps.
Press the required app.
Press the drop down list next to "Location Info".
Press the required setting.
