OPPO
Find X2 Pro
OPPO Find X2 Pro
f-086728f4-b0d2-429a-8352-3311ee5d9b92
f-d52cd822-81d0-4115-9550-ba7825f440ca
f-212778e6-1139-4a0d-ba4a-60ef541fc757
f-8bbe6955-04d3-4e03-ae59-3adf6fb35137
f-672211fe-e943-4812-b67c-13089674d856
f-9756173f-11b6-4bf5-8ff6-5b740c61d93d
Solution 1 of 4: GPS position usage for applications is turned on
Step 1 of 15
Step 2 of 15
Press Location.
Press Location.
Step 3 of 15
Press Location.
Step 4 of 15
Press the indicator next to "Location Service" to turn the function on or off.
Press Google Location Accuracy.
Step 5 of 15
Step 6 of 15
Step 7 of 15
Press the Return key twice.
Step 8 of 15
Press App Management.
Step 9 of 15
Press App Permissions.
Step 10 of 15
Press Apps.
Press Apps.
Step 11 of 15
Press Apps.
Press the required app.
Step 12 of 15
Press the drop down list next to
Step 13 of 15
Press the drop down list next to "Location Info".
Press the required setting.
Step 14 of 15
Step 15 of 15
