OPPO Find X3 Lite
Solution 2 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press Connection & sharing.
Press Personal hotspot.
Press Personal hotspot settings.
Press Name and key in the required name for the Wi-Fi hotspot.
Press Security.
Press WPA3 PSK to password protect your Wi-Fi hotspot.
Press Password and key in the required password.
Press the confirm icon.
Press the indicator next to "Personal Hotspot" to turn on the function.
