OPPO
Find X3 Lite
OPPO Find X3 Lite
f-c67adcea-a697-428f-aa51-77e050c7f1f6
f-3e7560b7-8f0b-4ae7-bad9-8ade3c925b7a
f-5b15905d-5469-4fe5-ad72-90b79f10d929
f-f8ce5b2c-070b-437e-ac3e-ec74a9ac4f1d
f-03d13522-0ffd-4770-a9f1-e19d28ced1ae
f-317ed498-c5e1-4d51-a6f6-dd67f4c2d858
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
