OPPO
Find X3 Neo
OPPO Find X3 Neo
f-705b3c89-f8b1-4b6b-9d24-ccd877c026a4
f-b34553d4-9316-4293-8b78-51d665374675
f-965502a6-03b2-4297-b7f4-8d5903a54db1
f-d1b3b821-45dc-42bc-971f-8e57348cc6ff
f-73c4675a-badf-481c-8747-170fb31c139e
f-eb44f1bc-f5f7-4e3f-a650-70003b40ed90
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
