OPPO
Find X3 Neo
OPPO Find X3 Neo
f-705b3c89-f8b1-4b6b-9d24-ccd877c026a4
f-b34553d4-9316-4293-8b78-51d665374675
f-965502a6-03b2-4297-b7f4-8d5903a54db1
f-d1b3b821-45dc-42bc-971f-8e57348cc6ff
f-73c4675a-badf-481c-8747-170fb31c139e
f-eb44f1bc-f5f7-4e3f-a650-70003b40ed90
Solution 2 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Step 1 of 9
Step 2 of 9
Press Wi-Fi.
Press Wi-Fi.
Step 3 of 9
Press Wi-Fi.
Step 4 of 9
Press Advanced settings.
Step 5 of 9
Press Wi-Fi Assistant.
Step 6 of 9
Step 7 of 9
Press the indicator next to "Auto-connect to the best Wi-Fi" to turn on the function.
Step 8 of 9
Press the indicator next to "Auto-switch to mobile network" to turn the function on or off.
Step 9 of 9
