OPPO
Find X3 Pro 5G
OPPO Find X3 Pro 5G
f-d9578667-1d15-4f35-a1fd-0e9bb68e6b26
f-84f1a5c8-4d53-4507-a623-1e8c4c31313e
f-57f481a5-0c17-4996-80ca-2bc4b8e8974a
f-18a1c559-e245-4fb9-bfb4-19fcd424586c
f-3f763c8a-c5f9-461c-8b79-bb7c0cb588be
f-ed7ab942-f79e-4b54-87c9-612e0fae9658
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
