OPPO
Find X3 Pro 5G
OPPO Find X3 Pro 5G
f-d9578667-1d15-4f35-a1fd-0e9bb68e6b26
f-84f1a5c8-4d53-4507-a623-1e8c4c31313e
f-57f481a5-0c17-4996-80ca-2bc4b8e8974a
f-18a1c559-e245-4fb9-bfb4-19fcd424586c
f-3f763c8a-c5f9-461c-8b79-bb7c0cb588be
f-ed7ab942-f79e-4b54-87c9-612e0fae9658
Solution 2 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Step 1 of 9
Step 2 of 9
Press Wi-Fi.
Press Wi-Fi.
Step 3 of 9
Press Wi-Fi.
Step 4 of 9
Press Advanced settings.
Step 5 of 9
Press Wi-Fi Assistant.
Step 6 of 9
Step 7 of 9
Press the indicator next to "Auto-connect to the best Wi-Fi" to turn on the function.
Step 8 of 9
Press the indicator next to "Auto-switch to mobile network" to turn the function on or off.
Step 9 of 9
