OPPO Find X3 Pro 5G
Solution 3 of 3: Your phone doesn't turn on correctly
Before you can turn on your phone, you need to insert your SIM into your phone.
If you're asked to key in your PIN, do so and press Done. The default PIN is 1111.
Press and hold On/Off.
Press and drag the circle downwards.
