OPPO
Find X5 Lite
OPPO Find X5 Lite
f-5729fa9f-b66a-4083-9710-63b8b08a51d5
f-40f06dc9-1bd2-43c3-8b2a-dd7ed45f379d
f-0b99ffe4-47f5-4249-ab8e-e9e0f9ae810b
f-5cb07c95-25f1-47d6-87b0-9be407a3f2e9
f-7f15af65-900c-4de0-a322-c47466bd2a03
f-2acac75e-dc76-497a-8c25-ddcb50cccf69
Can you make a voice call?
