OPPO
Find X5 Pro
OPPO Find X5 Pro
f-f63200ac-2ea2-44b0-b15e-2d8cc5b5f919
f-4d27fb34-5681-4e52-b30f-b47a49d47c75
f-f813ac54-ea1c-47a5-9e7a-6bc01ea9de30
f-9a33bd3b-969e-4b55-a081-4998b5ff1088
f-90e422b8-f97c-432f-b367-342cf4eea5e3
f-e6837c95-e259-4bad-b85a-ab54f378ff40
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
