OPPO
Find X5 Pro
OPPO Find X5 Pro
f-f63200ac-2ea2-44b0-b15e-2d8cc5b5f919
f-4d27fb34-5681-4e52-b30f-b47a49d47c75
f-f813ac54-ea1c-47a5-9e7a-6bc01ea9de30
f-9a33bd3b-969e-4b55-a081-4998b5ff1088
f-90e422b8-f97c-432f-b367-342cf4eea5e3
f-e6837c95-e259-4bad-b85a-ab54f378ff40
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Step 1 of 11
Step 2 of 11
Press Mobile network.
Step 3 of 11
Press the required SIM.
Step 4 of 11
Step 5 of 11
Press the indicator next to "Enable" to turn use of the SIM on or off.
Press the Return key.
Step 6 of 11
Press Calling.
Press Calling.
Step 7 of 11
Press Calling.
Press the required setting.
Step 8 of 11
Press Internet.
Press Internet.
Step 9 of 11
Press Internet.
Step 10 of 11
Step 11 of 11
