OPPO
Reno 5G
OPPO Reno 5G
f-abc28611-1b6a-415d-89ed-56e66252fab7
f-05f5b698-add6-42ad-ad10-2e916f61a144
f-6888a5d3-cece-4cb2-96fb-13de97377878
f-cbd51597-d85c-4da6-b9b9-5a6f96bb38be
f-38c6e5ed-2429-4c5e-aa78-95b435ef8204
f-d4b64a53-afe8-4b1c-b571-411f269884a8
Solution 1 of 3: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Press Wi-Fi.
Press Wi-Fi.
Press Wi-Fi.
Press Wi-Fi Assistant.
Press the indicator next to "Intelligently Select the Best Wi-Fi" to turn on the function.
Press the indicator next to "Auto-switch to Cellular Network" to turn the function on or off.
