OPPO
Reno13 Pro 5G
OPPO Reno13 Pro 5G
f-13069daf-491c-4ee3-b6f2-59c91fdd0d40
f-3e62d185-07c1-45d5-a223-a858ba2e954f
f-635c0ea8-039d-4a3e-b9d7-348e841b3185
f-b5b0f668-db02-49a2-8869-ac9ff7db426e
f-e8f2b068-f303-4f4f-b594-9a10efabb9e6
f-031192c4-64ef-4262-a251-fd014ae628e5
f-a9403534-daee-477f-b675-0098ba384b73
f-0ef9a2a9-38d4-4cc1-b21b-eff492a1dd39
Solution 1 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Press Wi-Fi.
Press Wi-Fi.
Press Wi-Fi.
Press Wi-Fi Assistant.
Press the indicator next to "Auto-connect to the best Wi-Fi" to turn on the function.
Press the indicator next to "Auto-switch to mobile network" to turn the function on or off.
